Can you listen to this and LMK if I have bad lifters?
Old Feb 25, 2026 | 11:12 AM
Brandon318's Avatar
Default Can you listen to this and LMK if I have bad lifters?
Cold start, specifically listen to the tap tap tap after I put it in D to drive away (around 26 seconds). Exhaust leaks are all sorted and it sounds loads better, so the only thing I'm left with is possible bad lifters? Or is this just normal clattery Disco noise?
Ignore the whiny PS pump. Another one is going in this week.
Old Feb 25, 2026 | 08:49 PM
Diesel Gypsy's Avatar
What does it do when it gets warmed up? And when fully warmed up, what temp does it run at?
Old Feb 25, 2026 | 09:50 PM
Brandon318's Avatar
Fully warmed up it is just a classic smooth, bass-y V8 rumble. No ticks. In fact that tappy tap noisy in the video is just about gone by the time I’m a quarter mile down the street.
Oil pressure normal. Water temp ~188.
Old Feb 26, 2026 | 01:44 PM
evil_goat's Avatar
Mine sounds exactly like this when cold, but I think my fixed exhaust leak is still leaking a little bit. When it warms up however, I get a different ticking which is definitely internal. Replaced the lifters, pushrods, rocker arms, timing chain and no difference in noise.
Old Mar 3, 2026 | 10:03 AM
adalton's Avatar
Mine has been making this sound since 113k miles now just about at 200k. Never cared enough to figure it out, and if it aint broken dont fix it.
Old Mar 3, 2026 | 03:14 PM
nashvegas's Avatar
Pretty much every Disco I’ve ever had makes that exact same noise. I’m fine with it. (pre facelift or facelift)
Brandon318
Jan 24, 2026 09:39 AM
spazmoid
Jul 5, 2018 03:06 PM
xsramo
Oct 11, 2017 11:40 AM
Tony Luna
Apr 28, 2015 12:31 AM
Gr8lite
Aug 12, 2010 10:36 AM
