Cannot take out EVAP valve--stuck!
Old Apr 3, 2020 | 09:04 PM
mr. choodles's Avatar
Default Cannot take out EVAP valve--stuck!
Hey guys,
I am trying to replace the EVAP valve. However, it is stuck and I cannot take it out. Can't even twist it out of the housing. Are there any tips or tricks to that? Should I let the car run for some time to warm up the hoses? What happens if I try to squeeze some WD40 between the housing and the hose? I am running out of ideas...
Thank you, --mc
Old Apr 4, 2020 | 10:04 AM
Best4x4's Avatar
Purge Control Valve? I've personally had to cut a few off and then use new hose on them. Sometimes they will pull out just fine, but I've also had a few that put up a fight. If cut off carefully you can then replace the hose and use some nice SS hose clamps.
Old Apr 4, 2020 | 11:34 AM
Yes, purge valve. Ok, so this is not good news for me. Where would I get these hoses?
Old Apr 4, 2020 | 03:33 PM
Best4x4's Avatar
5/16 fuel or PCV line will work
Old Apr 4, 2020 | 04:23 PM
rhyslegge's Avatar
Any NAPA or auto parts store sells bulk fuel or vacuum hose.
Old Apr 4, 2020 | 04:44 PM
redwhitekat's Avatar
Put some muscle into it
Old Apr 5, 2020 | 06:55 PM
Ok, so I put some muscle into it. Broke off the plastic clip that holds the fuel line on the right side of the purge valve. Broke off the metal clips that hold the valve on each side. Lost the metal clip on the black connector. Essentially, I must replace all the parts indicated by arrows in the pic below.
Is it safe to replace the metal clamps with stainless steel clamps with a bolt as a fastener?
Does anyone know the part # for the plastic clip?
Does anyone know where I can get the metal clip that popped out of the connector?
Thank you!
Old Apr 5, 2020 | 07:13 PM
Best4x4's Avatar
First step in removing the Purge Control Valve is disconnecting the end which connects to the Intake (squeeze and remove type connector), then the metal clip you just push/pull to remove the connector, then you gently pull it out from the plastic clips. Then unscrew the hose clamps, and remove the Purge Control Valve. On the OEM setup it used metal clamps you had to tear off literally, but a small flat blade usually could bend em open.
Old Apr 5, 2020 | 07:17 PM
Yep, so I moved on to the next part: re-assembly. The metal clips won't be re-used--I butchered them too much. Will try to use normal metal clips w screws. The plastic clip, however, is gone for good...
Old Apr 5, 2020 | 08:06 PM
Best4x4's Avatar
With the plastic clip totally removed you should be able to route a zip tie in the same way to secure it.
ROB99DISCOSD
Jan 27, 2018 04:43 PM
Savannah Buzz
Jul 18, 2011 09:35 PM
Rover Chris
Feb 13, 2011 09:45 PM
baburhan
Oct 12, 2010 04:16 PM
aublec22
Jun 10, 2009 05:25 PM
