Cascade option?
Old Dec 11, 2012 | 07:34 PM
Zonk872's Avatar
Default Cascade option?
Looking to gather some information on flushing my radiator. Currently have the Peak Flush kit in system with tap water. Plan is to flush it out and fill with Distilled for a few days before adding A.B's lower temp t-stat.
If the clean out does not appear to work with the Peak kit was contemplating Cascade. I've read that it can damage aluminum. Thoughts?
If anyone has tried Cascade- what kind of results did you see? What was the amount of Cascade that was used? I have a container of the liquid with Dawn in it.
Or does the Distilled White vinegar work better?
Old Dec 11, 2012 | 07:45 PM
CLR works wonders from what I've heard.
Old Dec 11, 2012 | 08:19 PM
A D2 radiator that is really sludged up will not be fixed by a flush. Just too late. Now as preventative maintenance, anything is an improvement over leaving the old coolant in there.
Old Dec 12, 2012 | 09:47 AM
I agree with Buzz, if you are close or over 100,000 miles your radiator can not be cleaned out per the size of the veins, even an honest radiator shop will tell you to not waste your money, buy a new one, plus your plastic tanks are very brittle and will crack sooner then later.
What ever you do, replace the t/stat, cause it will plug up if flushed, and the pressure cap cause they wear out.
Old Dec 12, 2012 | 10:07 AM
primussucks's Avatar
So, are you saying... Flush, then replace the thermostat, then bleed?
Is there an easy way to just clamp off the hoses, remove the thermostat, and replace, without loosing too much coolant?
Old Dec 12, 2012 | 02:49 PM
They make a flat nose vise grip pliers, but the old hoses won't like it. Just flush, replace stat, then fill with final coolant. Then bleed.
Old Dec 12, 2012 | 03:31 PM
wreckdiver1321's Avatar
I have a friend who has a Cummins with 265000 miles on it. He ran Cascade through everything and from shining the light down in the radiator, it looks way better than it did, almost brand new. Not sure how it would treat aluminum though.
Old Dec 12, 2012 | 03:42 PM
It don't eat the aluminum pans and such that SWMBO has put through thousands of torture tests followed up by the potscrubber cycle in the Whirlpool dishwasher. Of course eating her cooking can bring on some internal stress.....
Old Dec 12, 2012 | 07:57 PM
I think i'm going to try it when I switch to green coolant.
yloDiscoII
ROAMING WITH FRIENDS
Sep 2, 2021 01:54 PM
arod829
Nov 5, 2012 11:46 AM
jblanco
Jul 31, 2005 12:49 PM
VB_Rover
Jun 30, 2005 10:48 PM
lr3dave
Feb 9, 2005 12:23 AM
