Catalytic converters plugged?
Just park the truck in the dark garage and turn the light off and look under.
If your check engine light is on - don't drive it.
If your cats are below efficiency then you will get a code about that eventually
and be unable to smog it.
Otherwise, don't worry about it.
No check engine light - then don't worry.
