Catalytic converters plugged?
Old Jul 12, 2013 | 01:45 PM
earlyrover's Avatar
Default Catalytic converters plugged?
How can one determine, or know, if catalytic converters are plugged? I understand that such condition would cause a lot of heat build up in engine bay, but how can one best learn of condition of cats being plugged to some degree?
Old Jul 12, 2013 | 02:03 PM
If bad enough they will glow red. This is a false color IR image. You could use an IR thermometer and "shoot" each one, a wide spread of temperature may indicate one doing a lot worse than the other.
Old Jul 13, 2013 | 06:24 AM
jfall's Avatar
Just park the truck in the dark garage and turn the light off and look under.
If your check engine light is on - don't drive it.
If your cats are below efficiency then you will get a code about that eventually
and be unable to smog it.
Otherwise, don't worry about it.
No check engine light - then don't worry.
Old Jul 13, 2013 | 06:34 AM
BTW, cats are what cooks out the grease on the front drive shaft u-joints, and causes it to fail. If yours has not been replaced with fully greaseable, time to do that or upgrade the u-joints like the write up in our tech area.
Old Jul 13, 2013 | 09:37 AM
You will know if there is a problem when your service engine soon light comes on.
Old Jul 13, 2013 | 03:58 PM
earlyrover's Avatar
'If your cats are below efficiency then you will get a code about that eventually
and be unable to smog it."
Good points, but some of us don't have to meet any smog regulations!
Old Jul 13, 2013 | 07:25 PM
True, but if a cat plugs, you need to replace it before it burns your exhaust valves from the back pressure.
m1943
Aug 24, 2019 12:47 AM
targotsi
Oct 23, 2015 11:40 AM
DuplinDisco
Jul 20, 2008 03:25 PM
jdhuegel1
May 6, 2008 06:09 AM
jdhuegel1
Apr 29, 2008 03:58 PM
