Catalytic Sound?
Old Apr 7, 2016 | 01:36 PM
LR03NJ's Avatar
Default Catalytic Sound?
I checked almost all possibilities where the rough sound is coming from. The entire exhaust has no leak but the truck sounded like theres a hole in the exhaust especially when I start it in the morning. It was mentioned before somewhere here that the sound is like a tank (i forgot the name of the tank, lol) It quiet down when engine gets hot but broken muffler noise still audible. Can Catalytic converters make that sound too? Thanks
Old Apr 7, 2016 | 01:58 PM
jamieb's Avatar
Cats usually fall apart on the inside and rattle. Sometimes a leak sounds like a steam engine train. That would be air escaping from a crack or leak. Sometimes the bolts vibrate loose coming off the engine manifold. There are 3 bolts on each side. From there the Y pipe connects at the rear crossmember where the single pipe connects to the muffler. If it's leaking, it has to be at one of those places, otherwise you may have a crack, or have to look higher up where the manifold goes up to the engine on each side. There are bolts there holding each manifold on.
Old Sep 15, 2016 | 05:50 PM
NVDiscovery's Avatar
My buddy and I both have the noise that the OP mentioned. Any updates/thoughts here? Thank you.
Old Sep 15, 2016 | 08:19 PM
Alex_M's Avatar
I've seen those manifold to y-pipe gaskets just blow out the side. That would be my first thing I'd try.
mvjimenez
Jun 12, 2010 10:25 AM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
