cdl lock low ?? can't 04 d2 se7
Old Aug 18, 2013 | 10:05 AM
moorebl's Avatar
Default cdl lock low ?? can't 04 d2 se7
bought the truck used. its an 04 d2 se7. I have read and read some more. weather I am in parked or rolling 5-10 down the road putting it in neutral and trying to engage neutral on the transfer case and low is very hard. the transfer **** in my truck is normally positioned to the right when normal operation and when I immediately shift it to the left the lock light lights up on the dash. so lock high work now I have to use some pretty good force to push up and then the neutral light will blink sometimes but that's as far as I can get. I don't know when the last time the truck was put in locked low, but I cant get it there .. and suggestions how to remedy this situation.lube it or what not. any help will be great. thanks
Old Aug 18, 2013 | 10:19 AM
Lack of use leads to rust/corrosion of the linkage. May have to open up console and get at the parts. RAVE shop manual will be handy.
Old Aug 18, 2013 | 12:08 PM
FlyingZebra34's Avatar
After removing rust be sure to add grease around the joints to avoid future corrosion
Old Aug 18, 2013 | 12:47 PM
mln01's Avatar
High to Low takes MUCH more force than unlocked to locked. Do not be afraid! If you can get it into Low you're good.
Old Aug 18, 2013 | 12:55 PM
moorebl's Avatar
i guess the vein in my forehead wasn't enough force. its stuck. when locked to unlock i can do with 3 fingers. as for taking it apart haven't dug into the rave Manuel but i assume its taking apart the entire console.. is this correct
Old Aug 18, 2013 | 01:27 PM
YUP!!
Follow the Rave directions and completely remove the console, the remove the metal plate on the hump so you can then look down onto the t/case and shifter cables, clean and lube from them.
In the mean time, do not try a force the shifter or you will be buying some new parts.
Old Aug 18, 2013 | 05:24 PM
moorebl's Avatar
well I took a half can of WD40 fro underneath. maybe that will work come morning time. the positive direct force just isn't cutting it.
turbodave
Mar 29, 2019 07:22 AM
TRIARII
Jul 5, 2012 07:56 AM
rcshauger
Oct 3, 2008 05:36 PM
Classic89
Aug 10, 2007 08:58 PM
sflowr03
Nov 4, 2006 11:21 PM
