changing diff fluid
Old Jul 23, 2009 | 03:34 PM
khuds308's Avatar
for gear oil i have been using the mobile 1 SUV formula. i forget the weight, but it says SUV on the damn bottle. works great.
Old Jul 24, 2009 | 09:06 AM
chad420's Avatar
The brass plugs are 20 a pop.....anyone know where u can get steel ones cheaper???
Old Jul 24, 2009 | 09:33 AM
Try luck 8 or Todd, I think they have them in case iron.
Old Jul 24, 2009 | 09:36 AM
If you were more mechcanicly inclined and familiar with your truck, you would probably not use some general purpose gear oil. Rovers have 3rd members that are prone to failing based on wear of the spider gears and what you are using/suggesting, is not wise, especially in the heat of Arizona.
Old Jul 24, 2009 | 11:18 AM
sloppyjoe's Avatar
so does the 7qts of fluid cover the tcase and both diffs?
Old Jul 24, 2009 | 11:49 AM
chad420's Avatar
disco mike im new so be more specific on the name is it lucky 8 and who is todd???
Old Jul 24, 2009 | 02:03 PM
Borrow your wifes car and take the drain plug from one of your diffs down to The Home Depot, go to the plumbing section and buy 2 of those plugs and some teflon thread tape.
Less than $10 for everything.
Put the drain plug back into its hole and then tape up the treads on the fill/check plug and screw it in.
Send me $20 for the tip.
Old Jul 24, 2009 | 04:59 PM
salve7's Avatar
why put tape on the fill/check plug but not on the drain?
Old Jul 24, 2009 | 06:39 PM
Because the new fill plugs are not a exact fit and the drain plugs are.
Without the tape they may weep gear lube and they may not.
They are a very very very very close fit, others have don this with no problems, others yet needed the tape.
You can spend the $40 for 2 plugs or the $5 for 2 plugs and $3 for thread tape, the choice is yours.
DI's came with real fill/check plugs not the cheap plastic crap that DII's came with so we dont have this problem.
The drain/fill plugs from a DI will also fit a DII.
Old Jul 25, 2009 | 10:49 AM
Yes, 7 quarts will cover all 3.
As for Lucky8 or Todd Co, do a google search and they will pop up as 4 wheel parts suppliers.
aemnky606
May 28, 2010 06:40 PM
LRScott
Mar 4, 2009 08:39 AM
herblatham
Mar 12, 2008 10:32 AM
starcraft
Mar 4, 2008 08:45 AM
jakea4d2
Oct 26, 2006 11:17 PM
