Charcoal Canister Evap System
Old 02-04-2021, 07:22 PM
04disco2va's Avatar
Default Charcoal Canister Evap System
Hi All, Trying to get a number of odb codes fixed. Purge control valve error. Found the charcoal canister and hoses have a bunch of gunk in it and smells of old gas. Would like to replace parts in evap system but very expensive at AB and charcoal canister not available anywhere I looked. - Does anyone know of alternative less expensive options for the following parts ? Anything else that you recommend replace ?
canister purge valve WTV000060G
solenoid canister vent valve WTY000020G
charcoal canister Wtb000240
thanks for the help.
Old 02-05-2021, 06:55 AM
rock auto
Old 02-05-2021, 07:39 AM
04disco2va's Avatar
Thanks redwhitekat. I looked again but didn’t see any of these parts available. Maybe I’m searching the wrong way.
Old 02-05-2021, 08:51 AM
Use the Hyundai purge valve This is the canister valve. Can’t find the charcoal canister
Richard Gallant (02-05-2021)
Old 02-05-2021, 03:18 PM
04disco2va's Avatar
Thanks appreciate it. Making headway.
Old 02-05-2021, 10:20 PM
T-rex's Avatar
Old 02-05-2021, 10:51 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
I don't think SAI trucks use that smaller square canister. That's on non SAI trucks if I'm not mistaken. Hyundai Purge Control Valves used to be 10-15.00, but they've gone up lol. Cheapest I found was 25.00
Old 02-06-2021, 10:37 AM
04disco2va's Avatar
Thanks all for the help on this. Still looking for the canister but ordered the following from rock auto. Hopefully will work with my year and SAI?
HYUNDAI 2891022040(28910-22040) Vapor Canister Purge Valve / Solenoid $ 25.79 $ 0.00 1 $ 25.79 2004 LAND ROVER DISCOVERY 4.6L V8 STANDARD MOTOR PRODUCTS Z88001 Vapor Leak Detection Pump $ 75.79
Here is pic of what was in the truck.
Old 02-07-2021, 07:06 AM
mollusc's Avatar
I have one of those canisters; I pulled it off my parts truck before I junked it, figuring that I might need it some day. However, since these things don't seem to need replacing all that often, I'd be willing to let it go. Make me an offer if you want it.
Old 02-07-2021, 09:12 AM
04disco2va's Avatar
Thanks Mollusc. I’m told the part number for my truck is wtb000240. My 04 has the secondary air. I’ve seen similar canisters with part numbers ending in 090 and 083. Not sure it matters all of the canisters seem to look the same. I need to get to shop tomorrow and get number. Again thanks for being willing to part with yours. I’ll send you a private message to continue this.
Antmen
01-11-2020 06:52 PM
andrewd
07-31-2016 07:19 PM
Savannah Buzz
07-18-2011 09:35 PM
racer11x
Freelander
01-18-2009 08:46 AM
BuckMontecristo
07-27-2006 10:19 AM
Quick Reply: Charcoal Canister Evap System
