Charcoal Canister Evap System
Old Feb 4, 2021 | 07:22 PM
04disco2va's Avatar
Default Charcoal Canister Evap System
Hi All, Trying to get a number of odb codes fixed. Purge control valve error. Found the charcoal canister and hoses have a bunch of gunk in it and smells of old gas. Would like to replace parts in evap system but very expensive at AB and charcoal canister not available anywhere I looked. - Does anyone know of alternative less expensive options for the following parts ? Anything else that you recommend replace ?
canister purge valve WTV000060G
solenoid canister vent valve WTY000020G
charcoal canister Wtb000240
thanks for the help.
Old Feb 5, 2021 | 06:55 AM
redwhitekat's Avatar
rock auto
Old Feb 5, 2021 | 07:39 AM
04disco2va's Avatar
Thanks redwhitekat. I looked again but didn’t see any of these parts available. Maybe I’m searching the wrong way.
Old Feb 5, 2021 | 08:51 AM
Use the Hyundai purge valve This is the canister valve. Can’t find the charcoal canister
Old Feb 5, 2021 | 03:18 PM
04disco2va's Avatar
Thanks appreciate it. Making headway.
Old Feb 5, 2021 | 10:20 PM
T-rex's Avatar
Just did some of this myself - I don't have a source for the charcoal canister but take a look at these:
https://www.amazon.com/Bosch-0280142308-Purge-Valve/dp/B001COAS8M/ref=sr_1_1?dchild=1&keywords=0280142308+Bosch&qid=1606760995&sr=8-1 https://www.amazon.com/Bosch-0280142308-Purge-Valve/dp/B001COAS8M/ref=sr_1_1?dchild=1&keywords=0280142308+Bosch&qid=1606760995&sr=8-1
Amazon Amazon
No need to pay through the nose for some of this stuff
Old Feb 5, 2021 | 10:51 PM
Best4x4's Avatar
I don't think SAI trucks use that smaller square canister. That's on non SAI trucks if I'm not mistaken. Hyundai Purge Control Valves used to be 10-15.00, but they've gone up lol. Cheapest I found was 25.00
Old Feb 6, 2021 | 10:37 AM
04disco2va's Avatar
Thanks all for the help on this. Still looking for the canister but ordered the following from rock auto. Hopefully will work with my year and SAI?
HYUNDAI 2891022040(28910-22040) Vapor Canister Purge Valve / Solenoid $ 25.79 $ 0.00 1 $ 25.79 2004 LAND ROVER DISCOVERY 4.6L V8 STANDARD MOTOR PRODUCTS Z88001 Vapor Leak Detection Pump $ 75.79
Here is pic of what was in the truck.
Old Feb 7, 2021 | 07:06 AM
mollusc's Avatar
I have one of those canisters; I pulled it off my parts truck before I junked it, figuring that I might need it some day. However, since these things don't seem to need replacing all that often, I'd be willing to let it go. Make me an offer if you want it.
Old Feb 7, 2021 | 09:12 AM
04disco2va's Avatar
Thanks Mollusc. I’m told the part number for my truck is wtb000240. My 04 has the secondary air. I’ve seen similar canisters with part numbers ending in 090 and 083. Not sure it matters all of the canisters seem to look the same. I need to get to shop tomorrow and get number. Again thanks for being willing to part with yours. I’ll send you a private message to continue this.
Antmen
Jan 11, 2020 06:52 PM
andrewd
Jul 31, 2016 07:19 PM
Savannah Buzz
Jul 18, 2011 09:35 PM
racer11x
Freelander
Jan 18, 2009 08:46 AM
BuckMontecristo
Jul 27, 2006 10:19 AM
