Chasing the multiple misfires
Old Apr 4, 2025 | 09:43 AM
  #71
Tony Luna's Avatar
Originally Posted by Extinct
You have to swap the BCU along with the ECU and after you reconnect the battery turn the ignition switch on for 20 minutes and let it sit there to resync the IDM. If you move the truck no Domino's will start flashing unless you have a new instrument cluster, correction matching instrument cluster to go with the ECU and BCU
Thanks. Would the BCU require a VIN update?
Old Apr 4, 2025 | 07:41 PM
  #72
Extinct's Avatar
No, but the ECU/BCU are paired, and are paired to the IC and must be synced with the IDM/interior fusebox.
Old Apr 7, 2025 | 03:27 PM
  #73
Tony Luna's Avatar
Seeing some light at the end of the tunnel.
I installed the loaner ECU from TWS on Saturday morning. Performance tune (don't ask me what/how), so it really woke the engine up! Better throttle response and, from a SOTP standpoint, feels like even more oompf - especially off the line. Idle still seems a little rough, but no more codes. Up to about 8 key cycles and 100 miles - so far so good. Needless to say, ordering a new ECU from TWS - "for off road use only".
Because I am in CA, I need a stock ECU for passing smog testing. I plan on buying one from Goldwing Rovers. Can I use a Nanocom to program in my VIN? If so, does anyone have experience with this?
Oh, and this just happened. This thing definitely runs and looks better than new!
Old Apr 8, 2025 | 02:52 PM
  #74
Extinct's Avatar
No, Nanocom cannot sync BCU to ECU, you need shop with Testbook or a matched pair.
Old Apr 8, 2025 | 05:17 PM
  #75
Tony Luna's Avatar
Yep - thanks! Found a local indy shop that can do it. Hope this does it. I'll report back.
Thanks to all for your help on this!
Old May 22, 2025 | 02:10 PM
  #76
Tony Luna's Avatar
Well, to close this out...
Pretty sure cam lope was causing the misfires.
I drove down to SoCal last week and connected with Abran to help me program the VIN/handshake a replacement stock ECU I got from Goldwing Rover Parts to see it that would resolve the issue. Same thing - multiple misfires on all cylinders while idling. Otherwise, she runs very smooth and strong.
While in SoCal I was running AC more than usual and noticed no misfire codes. AC on = slightly higher idle = no misfires. AC off = lopey idle = misfires.
Ran AC during the smog inspection - PASSED!
Old May 22, 2025 | 02:21 PM
  #77
ahab's Avatar
That is awesome. Congrats!!!
Old May 22, 2025 | 07:22 PM
  #78
Harvlr's Avatar
Oh wow! I guess that’s good news. It took a lot of work to get here. So your cam would really like a faster idle then.
Old May 22, 2025 | 07:34 PM
  #79
Extinct's Avatar
Not required.
Old May 23, 2025 | 12:16 AM
  #80
JohnZo's Avatar
Default When is a misfire not a misfire?
By way of clarification, misfire codes are being produced, but there are no actual misfires in the cylinders. The jerky motion of a lopey idle at the flywheel is picked up by the crank position sensor as timing differences between teeth of the reluctor wheel. Then the ECU logic sets the misfire codes, based on timing differences. In this case, the engine is not actually misfiring, rather the logic that sets the codes is not suited to the new cam set up at low idle RPMs.
Glad you found that the A/C idle-up was enough to get you over the hump. Perhaps there's a way to wire in a switch or jumper to make the ECU think the A/C is on all the time.
