check engine light's on ..help
Old Mar 9, 2009 | 11:14 AM
jimbo97's Avatar
Thumbs up thanks
thanks disco mike , but still is it okay if i drove the car since its the O2 sensors that need to be change?
Old Mar 9, 2009 | 11:17 AM
jimbo97's Avatar
Thumbs up thanks fellas
i'll definetly do that thanks again guys .....
Old Mar 9, 2009 | 01:09 PM
okdiscoguy's Avatar
Make sure you are running at least 91 octane fuel. It will be ok to drive it for a bit, but it will cause to to run rich ar lean, depending on the fault. It is not good for the truck, it will make it carbon up. Get the replacements as soon as you can. Like it has been stated before, replace all 4 at the same time.
Old Mar 9, 2009 | 04:38 PM
roverguy7's Avatar
hold on a second... what were the codes?
Old Mar 9, 2009 | 05:48 PM
jimbo97's Avatar
Default O2 sensors
it says well my friend says replace O2 sensor bank 1 and bank 2 that's pretty much it .
Old Mar 9, 2009 | 05:51 PM
okdiscoguy's Avatar
Next time write down the code numbers. Helps more...
Old Mar 9, 2009 | 09:41 PM
roverguy7's Avatar
exactly, the only code that will outright say replace the sensor is for the sensor heater circuit, and even then you should check power if you have codes for both. but just so you know, even land rovers system says the o2 sensor is the problem for most fueling codes.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
