Check this out 2!!
Old Jan 2, 2012 | 01:51 PM
p4nth4's Avatar
Default Check this out 2!!
ok guys, i did what everyone suggested on my earlier post and disconnected my belt and started my truck and no noise. i then spun every component and pulley and no ticking noise either. i pulled off my shroud to tighten up my belt again and noticed a little play on the water pump pulley and was making a rattling sound. the pump doesnt move or is it leaking at all, also there is no overheating. the fan is also fine no wobble and moves like its supposed to. im really thinking that its my water pump pulley. my question is can i just replace the pulley or should i just replace the waterpump itself?? and is it possible for a pulley to make that loud ticking noise?? thanks again guys!
Old Jan 2, 2012 | 01:53 PM
p4nth4's Avatar
oh, one more question, how do i tighten the idler pulley without taking the whole thing off and do i need 2 people to do it??
Old Jan 2, 2012 | 08:02 PM
lordmorpheus's Avatar
Tighten the idler pulley? The idler pulley is the stationary pulley on the left hand side of the engine. Is it loose? With the belt off, you will me able to tighten the bolt that runs through the bearings in the pulley, if loose. If bolt is tight, bearings could be shot.
If you are talking about the pulley you had to move on the right side of the engine, to remove belt, you are talking about the tensioner. Is the pulley loose (wobbly) or is the tensioner not springing back into place once moved?
Old Jan 2, 2012 | 08:13 PM
If water pump is making any kind of noise (you said rattle) when the pulley on it is rotated, it is time for a pump. Bearing will get looser, leak will start, and when you can see it wobble it has already started eating aluminum. See pix of older pump.
Attached Thumbnails Check this out 2!!-p1030593.jpg   Check this out 2!!-p1030596.jpg
Old Jan 3, 2012 | 06:48 AM
p4nth4's Avatar
oh,ok. i loosened the idler pulley on the left. wrong pulley!! its on there right and nice and tight but my belt is still a little loose so could i tighten that with the pulley on the right of the engine? and also i did order a new pump as well. i was thinking maybe its not the pulley thats making that noise but the pump bearings behind it are loose and causing the impellor to hit against metal making that loud ticking sound. is that possible? thanks again for the quick response.
FlyingZebra34
Feb 22, 2014 05:39 PM
22Dirty
Jan 24, 2011 08:11 PM
tads
Aug 2, 2007 12:09 PM
Patrick
Off Topic
Oct 28, 2005 02:49 AM
mikemeyer0
Off Topic
May 27, 2005 02:15 PM
