Check those brake pipes!
Old Apr 28, 2023 | 09:39 AM
Pete C's Avatar
Default Check those brake pipes!
I recently had to slam hard on my brakes and evidently the weakened rear brake pipe burst. Luckily I had enough brake power left to avoid a collision. Upon inspection the 2 brake pipes that run along the top of the frame to feed the rear brakes are just as susceptible to rust as our beloved frames are. I’m taking the opportunity to replace most, if not all brake pipes and hoses along with calipers, discs and pads.
So if your frame is showing signs of rust, so too may your brake pipes be vulnerable. The most rusted section and the area that burst is between the body and frame just below the drivers area. Hard to explain why it was so isolated.
Old Apr 28, 2023 | 02:22 PM
jastutte's Avatar
glad you are ok.
Had a similar thing happen on my '01 Discovery. Fortunately, the hard lines aren't too difficult to replace. Four hands are better than two for some of the work, though.
Rover Newbie
Jul 9, 2015 06:00 AM
cogsley
Aug 13, 2014 03:24 PM
welling4x4
Sep 29, 2010 11:10 AM
skatelove303
May 27, 2009 08:06 AM
ArtemZ
Jun 29, 2008 03:04 PM
