Check your front drive shaft, it could save you a transmision
OK, welded the crack and ground it flush, measured side to side to make sure it was true. I was able to weld the crack with the transmission still in the truck. I ran a very fast bead and was on it for no more than a few seconds at a time, TIG with argon shield.
So far it's dry, now onto rebuilding the cardon joint.....
marlymarl
02-18-2010 05:13 PM
1991, check, denver, drive, driveshaft, front, gt, interceptor, jr, leaking, pan, rover, shaft, smashed, transmision, transmission, working
