Check your front drive shaft, it could save you a transmision
Old Nov 9, 2009 | 03:25 PM
SpdDemon426's Avatar
is it possible to rebuild your own drive shaft? Like if you get the spicer 1310 series U joints, can u just put it on the original tubing? or would you need new tubing?
Old Nov 9, 2009 | 03:48 PM
lipadj46's Avatar
Yes you can rebuild it. See the link in the post above it gives the u-joint and centering ball part numbers and everything.
Old Nov 9, 2009 | 03:54 PM
It says DII in the link, is that the same as the DI?
Old Nov 9, 2009 | 04:07 PM
lipadj46's Avatar
I'm pretty sure they are the same part numbers but not 100% sure. Better wait for spike or someone else with a D1. Its not as common because D1s came with greasable ujoints.
Old Nov 9, 2009 | 08:03 PM
Scott R's Avatar
OK, welded the crack and ground it flush, measured side to side to make sure it was true. I was able to weld the crack with the transmission still in the truck. I ran a very fast bead and was on it for no more than a few seconds at a time, TIG with argon shield.
So far it's dry, now onto rebuilding the cardon joint.....
edgarf23
Oct 2, 2013 07:39 AM
LeCarrie
Mar 9, 2013 05:32 PM
marlymarl
Feb 18, 2010 05:13 PM
tonher
Jan 7, 2008 08:14 AM
flyingcouch
Jan 22, 2005 08:25 AM
