Chirping Noise from underneath car
Numerous things could be wrong with it. Here's a helpful diagram from Tom Wood's site that explains what can fail:
Tom Wood's Custom Drive Shafts - Failures
I had worn out u-joints as well as a yoke that had a notch in it. You'll most likely see the damage on the yoke or the u-joints when looking closely. You can always put a photo of it up here and the forum can help too.
You Tube also has some educational videos on the LR front driveshaft and troubleshooting. This just happens to be one of them:
How long have you owned the vehicle and who replaced the driveshaft six months ago?
https://www.youtube.com/watch?v=WUdVrnARh20
It is dead simple you need :
2 x 9/16 wrenches - good wrenches not cheap
A couple of tire blocks the wedge shaped things you put under the rear tire
A jack stand
Process
Park on a level surface
Engage the hand brake
Block the rear tires
Jack the right side of you disco so the right hand front tire is just off the ground
Put the jack stand under there
Put your disco in neutral
Make sure your can turn the front right tire
Crawl underneath look at your front driveshaft you will see that there are 4 bolts on each end
Rotate the tire and take a look for any obvious damage
Now the fun part get the drive shaft where you can get a 2 of the bolts easily - with luck both ends
Back in the truck and put her in park
Pick a bolt put your wrenches on - make sure you have a good fit and take the bolt off
Get as many bolts out as you can
Back inside put the disco in neutral - get the next bolts lined up
Back to park
Continue removing bolts
A jack stand
Process
Back to park
JUKE179r (06-03-2019)
A jack stand
Process
Back to park
A jack stand
Process
Back to park
Well before I installed it, I went to my mechanic and he checked it out and said the driveshaft was in good condition. He said it might be the brakes so hes going to check them out next week.
