Chirping Noise from underneath car
Old May 30, 2019 | 08:44 PM
Extinct's Avatar
If you take it out you will be able to tell in a minute. Probably a 30 minute job to get it out.
Old May 30, 2019 | 10:01 PM
dealbergaria11's Avatar
Once I pull it out, what are signs that it will be bad?
Old May 30, 2019 | 10:20 PM
KernowDiscovery's Avatar
Numerous things could be wrong with it. Here's a helpful diagram from Tom Wood's site that explains what can fail:
Tom Wood's Custom Drive Shafts - Failures
I had worn out u-joints as well as a yoke that had a notch in it. You'll most likely see the damage on the yoke or the u-joints when looking closely. You can always put a photo of it up here and the forum can help too.
You Tube also has some educational videos on the LR front driveshaft and troubleshooting. This just happens to be one of them:
How long have you owned the vehicle and who replaced the driveshaft six months ago?
Old May 30, 2019 | 10:53 PM
https://www.youtube.com/watch?v=WUdVrnARh20
I have owned it since July and my mechanic replaced it in November. Are there instructions or a video that shows how to pull it out?
Old May 31, 2019 | 12:08 AM
Dave03S's Avatar
Yes! There are several on YouTube... Once you get under and look it is one of the easiest things of all... just a couple of open end wrenches is all you should need.
Old May 31, 2019 | 10:24 AM
Richard Gallant's Avatar
It is dead simple you need :
2 x 9/16 wrenches - good wrenches not cheap
A couple of tire blocks the wedge shaped things you put under the rear tire
A jack stand
Process
Park on a level surface
Engage the hand brake
Block the rear tires
Jack the right side of you disco so the right hand front tire is just off the ground
Put the jack stand under there
Put your disco in neutral
Make sure your can turn the front right tire
Crawl underneath look at your front driveshaft you will see that there are 4 bolts on each end
Rotate the tire and take a look for any obvious damage
Now the fun part get the drive shaft where you can get a 2 of the bolts easily - with luck both ends
Back in the truck and put her in park
Pick a bolt put your wrenches on - make sure you have a good fit and take the bolt off
Get as many bolts out as you can
Back inside put the disco in neutral - get the next bolts lined up
Back to park
Continue removing bolts
Old May 31, 2019 | 11:29 AM
A jack stand
Process
Back to park
Great I know what I will be doing this weekend!
Old Jun 4, 2019 | 09:43 AM
So???? what are you thinking....????
Curious minds would like to know.
Old Jun 4, 2019 | 11:28 AM
Well before I installed it, I went to my mechanic and he checked it out and said the driveshaft was in good condition. He said it might be the brakes so hes going to check them out next week.
Old Jun 4, 2019 | 12:35 PM
Best4x4's Avatar
Dust shields rubbing the rotors?
cobbcj7
Jul 30, 2017 12:16 PM
HBW1020
Jul 13, 2017 06:42 AM
windsoreight
Jun 28, 2014 04:52 PM
discoinchatty
Apr 6, 2010 10:13 PM
Darover
Aug 22, 2008 04:30 PM
