Chugging from sound from plenum area and rough idle
Old Apr 16, 2016 | 09:08 PM
lr3_ovrlnd3r's Avatar
Default Chugging from sound from plenum area and rough idle
Ok, I need a little help. Was driving my kids truck and I noticed at the light I got a rough idle, along with a chug chug chug chug. SES light is now on....too late to go get codes read. It is acting like a cylinder is not firing. It is an air sound, and not an exhaust leak. Just had HG replaced with water pump, new wires and plugs, no leaks coolant level good. There is no metallic sound, no banging or tapping. Could my plugs or wires have gone bad in less than 1000 miles? They are not top end wires and not sure of plugs. I put "stethoscrewdriver" on valve cover and plenum and everything sound ok. Exhaust gaskets just replaced and noise is definitely from top. Vacuum leak? Bad plug(s)? Help.
Old Apr 16, 2016 | 09:32 PM
UPDATE: I was pulling plug wires to check plugs and low and behold this little gem stayed on the plug. I crank truck up with wire off and it runs exactly the same. Number 4 cylinder was not firing due to bad plug wire. Or at least thats how it appears.
Old Apr 16, 2016 | 10:55 PM
UPDATE 2: Plug wires changed no difference. See video link. It is NOT a tap or banging sound. It is air. I am waiting for friend with code reader.
dillhole
Feb 20, 2020 02:30 PM
TheMightyMoose
Nov 2, 2013 11:52 AM
pedro_malo
Jun 18, 2008 05:51 PM
mr.47
Mar 27, 2007 02:45 PM
