Cigarette Lighter Mod D1/D2:
Old Nov 26, 2017 | 08:33 PM
  #31
uvodee's Avatar
Default cig lighter fix
Originally Posted by Best4x4
Did you meter the leads going to the cigarette adapter or just from the unit itself?
i measured it with the leads poking inside the adapter and liek i said 0.3 volts
Jean-Pierre
Old Nov 26, 2017 | 08:36 PM
  #32
uvodee's Avatar
You mention checking/changing fuses, but did you check voltage at fuse? If you have voltage at the fuse, I'd probably pull the console side panel over far enough to see if wire are connected.
Brian.
i build high end tube amplifiers as a hobby and am ashamed to say i did not checked it your that way.... shame on me for a few weeks........... will try this tomorrow
Old Nov 26, 2017 | 11:28 PM
  #33
uvodee's Avatar
dci
i did it again, but this time inside the adapter AND at the fuse.
adapter = 0.3 v
fuse = 13,80 while running, 12.0 when not running
Old Nov 28, 2017 | 10:26 AM
  #34
uvodee's Avatar
Default cig lighter
Brian.
I will remove it this weekend. I tested the fuse box and these is current so it can only be an issue from the wiring after the fuse.
ferrelltodd
Dec 22, 2008 06:09 PM
thelokolobo
Mar 14, 2008 01:06 PM
jbond0076
Jul 16, 2007 09:23 AM
thisisheaven
Jul 12, 2007 01:03 AM
cowgirl1989
Jan 5, 2006 08:01 PM
