Clunking noise?
I have a clunking noise that i hear when ever i give my discovery 2gas (accelerate). Im thinking that it is a worn out U joint or could it be that rubber piece that is on the shafts? Any ideas would be much appreciated.
Thanks
Thanks
So what have you done so far to find the problem, have you checked your roto flex, how about greasing both slip shafts, greasing the u-joints and have you replaced the two rear u-joints on your front drive shaft where it hooks to the t/case?
Mike
Mike
Stacey, Rovers are known for their klunking sounds if you hit the gas and then the brakes, it is normally usual. The one thing to do though is to make sure that your u-joints are all greased, that your rotoflex is not cracked and that the 2 u-joints that attach to the t/case have grease fittings on them.
Mike
Mike
thanks guys
iv checked my joints and grease fittings but it makes a loud clunk when im coasting and then i accelerate.(it clunks then). i think i have it narrowed down to the front drive shaft. Are the transer cases prone to have problems? because i believe that it is coming from there.
trangle23
Nov 20, 2006 12:39 PM
tobob1
Oct 3, 2006 11:37 AM
