Clunking noise?
Old May 20, 2007 | 10:54 PM
LandRoverDiscoDos's Avatar
Default Clunking noise?
I have a clunking noise that i hear when ever i give my discovery 2gas (accelerate). Im thinking that it is a worn out U joint or could it be that rubber piece that is on the shafts? Any ideas would be much appreciated.
Thanks
Old May 21, 2007 | 08:13 AM
Default RE: Clunking noise?
What year and model, how many miles of the truck?
Mike
Old May 30, 2007 | 12:54 PM
01 discovery 2, 69000 miles on it.
Old May 30, 2007 | 03:45 PM
So what have you done so far to find the problem, have you checked your roto flex, how about greasing both slip shafts, greasing the u-joints and have you replaced the two rear u-joints on your front drive shaft where it hooks to the t/case?
Mike
Old Jun 8, 2007 | 10:34 PM
Stashf's Avatar
6th Gear
Did you ever find out what the clunking noise is? I hear it on and off my truck as well but have never yet discovered by both local mechanic or dealership what it is!
Stacey
Old Jun 9, 2007 | 07:11 AM
Stacey, Rovers are known for their klunking sounds if you hit the gas and then the brakes, it is normally usual. The one thing to do though is to make sure that your u-joints are all greased, that your rotoflex is not cracked and that the 2 u-joints that attach to the t/case have grease fittings on them.
Mike
Old Jun 16, 2007 | 02:15 AM
thanks guys
iv checked my joints and grease fittings but it makes a loud clunk when im coasting and then i accelerate.(it clunks then). i think i have it narrowed down to the front drive shaft. Are the transer cases prone to have problems? because i believe that it is coming from there.
jtm964
Freelander
Sep 20, 2008 03:01 AM
Disco_one
Aug 21, 2008 05:46 PM
bonedoc
Jun 1, 2007 12:26 PM
trangle23
Nov 20, 2006 12:39 PM
tobob1
Oct 3, 2006 11:37 AM
