Code 0340
Hey guys... the Discovery relation continues.
I just replaced my timing chain and a few other things.
As I cleaned my oil encrusted cam shaft position sensor contacts with some CRC electrode contact cleaner, the solvent severely damaged the plastic plug. Basically it melted the section nearest the wires-ugly.
Thus I wasn't surprised when I got a 0340 code accompanied by a slight hesitation to start and a noticeable loss of power. I did the typical things like adjust the plug connection... nothing.
My conclusion was that the solvent damaged the connectivity and with such short leads I doubted repairing it was possible. So I chocked it up, grudgingly ordered a new $en$or, installed the part and cleared the code with my reader.
Surprise, I still have the 0340 code and a noticeable loss of power.
Anyone have any pointers with this? I've read that the 340 code can sometimes indicate a crank shaft sensor issue. The cost of the cam sensor just tanked me. I really don't want to put more money into her unnecessarily.
Thanks
Thanks
Just one code... 340!
Adding to my description- The truck has a very slight hesitation to start, but once started, runs smooth and quiet. One would suspect it was a false code, but I have a significant lack of power and noticeable delayed shift pattern.
https://landroverforums.com/forum/ge...n-30745/page2/
Just read this thread regarding code 0340. Turns out the engine had the wrong cam gears.
As mentioned, I just replaced the timing chain and cam gears.
I'm really hoping that Atlantic British sent me the correct parts for my D2. Unfortunately they're closed for the day. If anyone with experience could take a glance at the set I installed I'd be grateful. They look correct, but I may be missing a subtle difference.
Thanks, Michael
Thanks, Michael
As much as I enjoy this vehicle, I'm highly considering putting her up for sale. You may see the last of my threads in short time.
Well I'm no closer to resolving this today than I was two weeks ago.
BA has been more than accommodating and sent me a new timing chain and gears to compare with my old set. In addition, they suggested rather confidently that the 0340 code may be caused by a faulty crank shaft position sensor. I know Mike... you and I spoke and we both agreed is was a very long shot. But they said I could install it and if it didn't work return it.
I installed the crank shaft position sensor today. What a pain in the goose! An easy 20 minute project with an additional 60 minutes of Houdini like arm and finger maneuvers to uncouple the plug. Something I hoped not to do again. I cleared the code and immediately saw no improvement in power and the code returned shortly there after. Return the CSPS? Agggggggg!
What I did discover, is that the holes (for the cam shaft position sensor) in the new cam shaft gear are not identical to the holes in the original part. The attached pictures embellish the discrepancy slightly, but none the less, there is a distinct difference.
Since the cam shaft position sensor works in conjunction with the gear holes, could a small machining error like this be enough to cause a 0340 cam shaft position sensor error? If my timing is off because of this discrepancy, can the ECU settings be adjusted to resolve the error?
Any advise would be greatly appreciated.
Michael,
I just did this job. Your timing if OFF!!!!!!
In your picture your key points straight up towards 12 o'clock. It should be point at 2 o'clock roughly. See my pictures. I also took pictures of cam and crank sprockets and you will see timing marks on them as well as the position of the crank key. Your picture does not look like this. Like I said, your key points at 12 o'clock and it should be at 2 o'clock roughly when the cam marks is pointed at 6 o'clock.
Just so you know.....marks on the new sprockets are a little different shape than the stock sprockets.
This is why your cam sensors thinks it's off.....because it is compared to the crank position.
Hope this helps. I just seen this thread...sorry. Wish I seen this sooner.
Boris
Boris
Buzz,
His is an '03, which means he's got 4.6l. But even 4.0l is done in the same manner.
Let me know if you agree with my theory please.
Thanks.
Thanks.
