Which Code Reader?
Old Sep 28, 2015 | 09:52 PM
austin_green1985's Avatar
Default ODB2 to Bluetooth adapter
Also, I am fan of the bluetooth OBDII readers.
First, I ordered an ODB2 to Bluetooth adapter and hooked it up. Simply pair it to your Android device (apple is more complicated) like any other Bluetooth device. I did have to restart my phone before it'd pair but my tablet paired right away. This is the one I bought:
MINI ELM327 Interface Viecar 2.0 OBD2 Bluetooth Auto Diagnostic Scanner Support Android/Windows
Bluetooth interface is highly customizable and will show TONS of parameters with the ISF ECU. I have gauges showing 0-60, 1/4 mile, speed (from ECU or GPS), Engine speed, torque, horsepower, afm, voltages, etc. It'll also allow you to see and clear codes off the ECU. That alone was my excuse to buy it to the wife! There are different themes to the gauges, with infinite gauge layouts you can use.
I'd highly recommend this to anyone with an extra $15 lying around. The app is $4.99 and the device is $9.99.It's a great cheap monitoring tool that I'm looking forward to using in autocross videos. It'll do logging and everything that the more expensive tools will do for much less money. The options I mentioned are just a few of the monitor able parameters of the ECU. I'm in no way affiliated with this but I'm having a blast trying out this technology!
So far the best I've run is a 5.0 0-60 (tire spin in the cold).
Old Sep 29, 2015 | 03:38 AM
motom's Avatar
4th Gear
The Nanocom Evolution from Black Box Solutions seems to be the preferred tool in Norway for discoveries (D1,D2, and now some D3/L3 etc). I'm sure there are plenty of other readers but not sure how many of them can access all the different ECUs and also program them.
Old Oct 1, 2015 | 07:39 AM
MPDano's Avatar
Originally Posted by Robert Booth
some good options here.
What I should have mentioned is that i'd really like the option to be able to program systems, (keys), see what the BCU is doing and for that I'd need somthing like a Hawkeye, Lynx , Black Box Solutions etc
Can anyone weigh in on which one of the programming units they prefer ?
Following this thread as I too like these models but lack the funds to buy such a tool. Is there a less expensive tool that has the features of the above diag tools? All the three are around $500
Old Oct 1, 2015 | 07:54 AM
drowssap's Avatar
if you want to be able to make program changes instead of reading and clearing codes that is what it will cost.
Thou i have seen the hawkeye in the Eruo and Australian markets for less, Australian dollar is real weak now. there is no weight so shipping shouldn't be an issue.
Old Oct 1, 2015 | 08:30 AM
MPDano's Avatar
Most def want to write than just read as I already have an ODB Reader by Actron. Good info on Aussy dollar. Thanks for the info.
Old Oct 1, 2015 | 01:03 PM
me6067's Avatar
I have the lynx system and Have used it so far for various things such as key programming and resetting adaptive values for transmission and engine ecu. If you have any particular question I would be more then happy to try some of its capabilities on my D2.
Old Oct 3, 2015 | 04:43 PM
lrguy46's Avatar
The icarsoft930i is a good little machine will read sls and abs, and is an open system for all LR 99 and up
Hi
I second that proposal as it's one of the least expensive of the scanners but does the job.
Old Oct 4, 2015 | 11:51 AM
humroot's Avatar
Originally Posted by dr. mordo
I'm a big fan of the bluetooth OBDII readers you can get on Amazon. I use Torque on my phone to interface with them.
That said, I've had 1/4 defective on arrival.
X2. This is what I use.
Old Oct 14, 2015 | 01:09 AM
moloha's Avatar
parts of our member vote for autocom or mangoose SDD PC-based software, personally i have the mangoose cable
blake989
Dec 6, 2007 11:44 AM
bookerbr
Feb 25, 2007 03:27 PM
KevC
Jan 20, 2007 08:21 PM
skins
Dec 29, 2006 03:56 PM
