Which Code Reader?
Also, I am fan of the bluetooth OBDII readers.
First, I ordered an ODB2 to Bluetooth adapter and hooked it up. Simply pair it to your Android device (apple is more complicated) like any other Bluetooth device. I did have to restart my phone before it'd pair but my tablet paired right away. This is the one I bought:
MINI ELM327 Interface Viecar 2.0 OBD2 Bluetooth Auto Diagnostic Scanner Support Android/Windows
Bluetooth interface is highly customizable and will show TONS of parameters with the ISF ECU. I have gauges showing 0-60, 1/4 mile, speed (from ECU or GPS), Engine speed, torque, horsepower, afm, voltages, etc. It'll also allow you to see and clear codes off the ECU. That alone was my excuse to buy it to the wife! There are different themes to the gauges, with infinite gauge layouts you can use.
I'd highly recommend this to anyone with an extra $15 lying around. The app is $4.99 and the device is $9.99.It's a great cheap monitoring tool that I'm looking forward to using in autocross videos. It'll do logging and everything that the more expensive tools will do for much less money. The options I mentioned are just a few of the monitor able parameters of the ECU. I'm in no way affiliated with this but I'm having a blast trying out this technology!
So far the best I've run is a 5.0 0-60 (tire spin in the cold).
The Nanocom Evolution from Black Box Solutions seems to be the preferred tool in Norway for discoveries (D1,D2, and now some D3/L3 etc). I'm sure there are plenty of other readers but not sure how many of them can access all the different ECUs and also program them.
some good options here.
What I should have mentioned is that i'd really like the option to be able to program systems, (keys), see what the BCU is doing and for that I'd need somthing like a Hawkeye, Lynx , Black Box Solutions etc
Can anyone weigh in on which one of the programming units they prefer ?
if you want to be able to make program changes instead of reading and clearing codes that is what it will cost.
Thou i have seen the hawkeye in the Eruo and Australian markets for less, Australian dollar is real weak now. there is no weight so shipping shouldn't be an issue.
I second that proposal as it's one of the least expensive of the scanners but does the job.
X2. This is what I use.
DiscoBenjamin
Oct 14, 2011 05:53 PM
