Coffee-Colored Differential Fluid
Old Apr 1, 2012 | 09:00 PM
steveo2000's Avatar
Default Coffee-Colored Differential Fluid
Changed both front and rear diff fluid today in my 2000 Disco 2. I put 85-140 in for those curious.
The old oil in the rear diff looked like a really-viscous coffee with cream. Water? Any ideas guys?
Thanks in advance,
Steve
Old Apr 1, 2012 | 09:18 PM
outdoor7or24's Avatar
I'd say it is not uncommon to find water getting into these areas if driven through water crossings over time.
How do your seals look?
Changing fluid every 2-3 years helps keep everything fresh....
Old Apr 1, 2012 | 09:22 PM
Condensation collecting in the diffs is not uncommon, especially if the axle breathers are clogged.
Gear oil is cheap, change it once a year, thats what I do, every spring.
Old Apr 1, 2012 | 09:32 PM
steveo2000's Avatar
Thanks, guys. I'll have a look at the seals. The diffs don't appear to leak, but I'll have a look at them.
Spike, where are the axle breathers located? I just looked in RAVE for a picture or reference to them ,but I didn't come up with much.
Old Apr 1, 2012 | 09:50 PM
They are ontop of each axle near the diff's, there will be a hose running from it.
Old Apr 1, 2012 | 09:54 PM
steveo2000's Avatar
Thanks!
Old Apr 1, 2012 | 11:36 PM
And the banjo bolt that holds the lines gets clogged with mud or just dust and condensation (man-made mud).
Attached Thumbnails Coffee-Colored Differential Fluid-p1030610.jpg   Coffee-Colored Differential Fluid-p1030613.jpg
Old Apr 2, 2012 | 06:49 AM
steveo2000's Avatar
Thanks again SB. Sounds like I just remove the bolts and clean them out?
Old Apr 2, 2012 | 08:00 AM
Yep - and blow out lines with some air from a can or compressor.
BCDisco2Lando
Apr 15, 2014 02:06 PM
outdoor7or24
Apr 2, 2012 05:23 AM
LRD2&ME
Sep 26, 2011 11:38 AM
Desert Roadrunner
Feb 27, 2011 12:59 PM
Spencerfitch
Oct 7, 2010 12:43 PM
