Coils have no spark
Old Sep 10, 2012 | 07:54 PM
jycsalas's Avatar
Default Coils have no spark
Hello,
Ignition coils on a 2000 DII has no spark? Engine turns over and wants to start, there is good fuel pressure at the fuel rail, new battery and no codes.
Where should I start?
Old Sep 10, 2012 | 09:00 PM
jafir's Avatar
Crank sensor is where I'd start.
Old Sep 13, 2012 | 10:54 AM
mln01's Avatar
Doesn't a failed CKPS also shut off the fuel pump? No spark from either coil? Doesn't make sense that both coils would fail at the same time. Bad ECM?
Old Sep 13, 2012 | 11:48 AM
Josh, where have you been for so long, thought you fell off your island.
When does it happen, all the time, some time?
I would start with a crank sensor, yes it can shut off the fuel pump signal, coil signal or both.
Let us know what you find.
Old Sep 13, 2012 | 01:35 PM
handsome rob's Avatar
I would suggest the CPS, when it went on mine it did not shut off the fuel pump. Let us know what you find out.
cta
Aug 17, 2012 08:10 AM
me 2
Apr 11, 2012 08:56 AM
rohnbarrow
Aug 24, 2011 10:35 AM
tommytwotone
Oct 26, 2009 10:59 PM
