coolant change....went poorly
Old Dec 1, 2014 | 06:47 AM
drowssap's Avatar
you should flush the system with water to get all that dexcool out
Old Dec 1, 2014 | 07:09 AM
kgov's Avatar
Is there a thread on how to flush effectively?
Old Dec 1, 2014 | 09:33 AM
abran's Avatar
The real problem is how to flush the system with distilled water? I'm waiting to do mine until I rig some sort of pressurized flushing system.
Old Dec 1, 2014 | 09:36 AM
drowssap's Avatar
fill it with distilled water let it run, drop the water and use you'res or you neighbors leave blower to get the residual water out of the block
Old Dec 1, 2014 | 10:57 AM
cosmiccharlie's Avatar
$8
Brass Upgrade Coolant Bleeder Screw for BMW Mini 17111712788 All BMW New | eBay
Old Dec 1, 2014 | 11:13 AM
abran's Avatar
there you go! I'm going to try that.
Old Dec 1, 2014 | 06:34 PM
stb616's Avatar
I know, but it's been cold here....too cold for that kind of project. I'm guessing it's been flushed recently because what came out of it looked very clean. I used 3 1/2 gals of 50/50 peak global lifetime so there's no risk of it doing the gel thing. It's amazing how much you can get out if you gently blow into the hoses.
When I was trying to get the broken bleed screw out of the hose, the entire thing fell out. I barely even pushed on it so I'm thinking it would failed soon anyway. I ran down to the dealership and bought a new, updated style upper hose assembly for $100....but it's fixed and bled. Seems to run cooler and I have heat. Seemed to settle at 186 @ idle. I'll drive it tomorrow and see if it actually runs cooler.
Old Dec 2, 2014 | 06:31 PM
OffroadFrance's Avatar
D2 brass bleed screw New Brass Coolant Bleed Screw Land Rover Range Rover Discovery Metal | eBay
whilst bleeding turn the ignition key to position 2 and set A/C on max heat to fully open the heater waterway solenoids. Leave the ignition key in position 2 whilst bleeding.
Old Dec 2, 2014 | 09:40 PM
lordmorpheus's Avatar
Petrol D2s have no heater valves or solenoids. Just a steady flow of coolant through the heater core all year round regardless of what the HVAC setting is, or if the HVAC even works.
binvanna
Jan 9, 2013 04:17 PM
faltskog5450
Feb 13, 2010 04:47 AM
buddy22
Nov 30, 2007 04:05 PM
ser3
Jul 27, 2007 01:08 PM
GregHaugen
Oct 27, 2006 12:44 AM
