Coolant Leak
Old Jan 3, 2013 | 04:49 PM
benc988's Avatar
Default Coolant Leak
Hey all,
I have a 2001 Disco II, and I have been having this coolant leak for quite some time, and its getting to the point where I am refilling the coolant tank every week. I finally did a pressure test and it seems like this is where the leak is coming from (see picture). It seems that it is cracked and its leaking. Does anyone know what this part is called? And if it's a hard job? I dont have much experience with cars, but I have worked on them and know how to put things back the way I took it apart.
Also, I am still concerned about the leak and i feel like the leak is coming from underneath, as opposed to above. There is a burning smell when i turn the car off, but not sure if thats anything to worry about. Anyway, I am going to try this and hope that it works, but i need to know the name of the part first.
Old Jan 3, 2013 | 04:52 PM
aarongregor's Avatar
thats your thermostat. Super easy to take out and around $35 dollars to replace.
Old Jan 3, 2013 | 04:57 PM
replace it with a Motorad 439-180 tstat, I have that in mine and it helps it run a little cooler. I got mine off Amazon
Old Jan 3, 2013 | 04:58 PM
benc988's Avatar
Thanks alot!! Just called and the part is 38.50, and is a lot better than paying $165 (price that was quoted to me). Hope this works, and can finally put this issue to rest.
Thanks again!
Old Jan 3, 2013 | 06:35 PM
It looks like a heart, has 3 hoses running to it and they are held on with a pinch type hose clamp. Welcome to the wonderful world of owing and working on your Rover! A garage wanted $165 to change it?
Old Jan 4, 2013 | 10:17 AM
benc988's Avatar
Yup! 165, and he wouldnt even tell me what the part was called. Im sure I can get it fixed elsewhere for cheaper, but i think I can tackle this myself. Do I need to buy new pinch type hose clamps?
Old Jan 4, 2013 | 10:49 AM
BrandonS's Avatar
I use a big set of vice grips; anything with a wide enough mouth than can clamp down will do. It's a huge PITA to get them into the space, lock them on, and then try to manuever the snap ring without it springing back to life so it may be worth buying them.... I've never owned a set. Everytime I pull this hose off I keep forgetting to buy some normal hose clamps to replace them with. IMO I would get some regular hose clamps that you can undo with a screw driver.
Old Jan 4, 2013 | 11:02 AM
And strongly consider the 180F warm weather soft spring stat as the replacement.
Old Jan 4, 2013 | 11:04 AM
ZGPhoto's Avatar
Depends on where you live I guess. I wouldn't want the 180 personally, it was -14 2 nights ago in VT.
Old Jan 4, 2013 | 11:06 AM
benc988's Avatar
I would be lying if i said i knew what you were talking about....
