Coolant leak, rough idiling and check engine light
That shop is a ripoff.
You can fix it yourself in a garage.
I did fix mine in a parking lot in Boulder CO in March 2012.
Don't pay all that.
Here is about what you need to do.
Flickr: Landroverdude2's Photostream
Don't pay all that.
So I got confirmation from the shop that is the head gasket and the leak that I have if affecting the oxigen sensor. Are you ready for the estimate.... $
3,983.81 for parts and labor 1,787 for labor and 1,971 parts.
Please see estimate.
CHECK ENGINE LIGHT- ROUGH IDLE
R/R CYLINDER HEAD GASKET
Labor: $1,787.50
STC 4082 HEAD GASKET SET-N 1.0 @ 345.96 =$ 345.96
ERR 2944 HEAD BOLT-N 6.0 @ 8.25 =$ 49.50
ERR 2943 HEAD BOLT-N 14.0 @ 8.20 =$ 114.80
MGM 000010K Throttle Body Defroste-N 1.0 @ 46.88 =$ 46.88
ERR 7280 GASKET, TIMING COVER-N 1.0 @ 21.65 =$ 21.65
STC 4378 Water Pump w/ Gasket-N 1.0 @ 245.63 =$ 245.63
MHK 100920 SENSOR, OXYGEN-N 1.0 @ 156.63 =$ 156.63
ERR 6490 SEAL, FRONT CRANK-N 1.0 @ 18.95 =$ 18.95
OIL,10W30SYN PENNZOIL SYNTHETIC-N 8.0 @ 8.25 =$ 66.00
ANTIFREEZE ANTIFREEZE,GREEN QUART-N 2.5 @ 7.17 =$ 17.92
ERR3340 OIL FILTER-N 1.0 @ 19.85 =$ 19.85
SEAL-AL ALUMINUM DRAIN PLUG SE-N 1.0 @ 1.14 =$ 1.14
BRK BRAKE/METAL CLEANER-N 2.0 @ 8.30 =$ 16.60
PARTS, MISC PARTS THAT MAY BE NEED-N 1.0 @ 850.00 =$ 850.00
Labor 1,787.50
Parts 1,971.52
Haz Waste 1.41
Shop Supplies 52.83
Tax 170.55
Total $3,983.81
Payments 0.00
Bal Due 3,983.81
Does this sounds right?
This is not a dealership but an independent mechanic who works on LR.
Labor: $1,787.50
Labor 1,787.50
Parts 1,971.52
Haz Waste 1.41
Shop Supplies 52.83
Tax 170.55
Total $3,983.81
Payments 0.00
Bal Due 3,983.81
Jfall how long did it take to do the job? besides the items listed and tools what other items are needed also what is the skill level needed to do the Job?
Can Bar's leak damage any part of the engine?
I looked at the cost of the parts from British Atlantc and the total for the same parts came to $590.00 + shipping.
For the other questions asked.
It has 71,000 miles.
I use premium gas 93 octane.
The on going rate for labor is between 70 and 90 dollars an hour.
Thanks for all the info.
