Coolant overflow bubbling?
Old 12-05-2022, 04:50 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
Yes, I run the cap one turn loose to alleviate the pressure. It makes no difference in how hot the engine runs, it just raises the boiling point by raising the pressure in the system. Both are problematic.
The pressure can cause all of the non-metal component to crack and I believe also increases the probability of a blown HG. I have cracked/split radiator tanks, coolant bottles, hoses, and the lower plastic spider before I finally began running one turn loose.
The higher boiling point is also a problem because it enables the engine to run hotter when the cooling system is not up to snuff. Much like a pot of boiling water cannot exceed 210 degrees as long as there is water in it, a non-pressurized engine cannot exceed 230 degrees as long as there is coolant in it. Hotter is definitely worse with these engines, overheating not only causes blown head gaskets but also is the root cause for the cylinder slippage and walked cam bearings that are common after overheating experiences.
Good luck with your new truck, check out my list threads here: https://landroverforums.com/forum/di...e3/#post674154
and here: https://landroverforums.com/forum/di...t-seats-96444/
WildPackofFamilyDogs
07-08-2022 01:59 AM
flyingmada
05-11-2019 03:36 PM
DiscoWall
03-17-2018 08:04 PM
toad2
10-09-2011 09:48 AM
ajh
10-20-2007 11:22 PM
Quick Reply: Coolant overflow bubbling?
