Coolant squirting from block.
That's an amazing head gasket leak. Epic. I had one like that in the back of the engine once. I thought it might just go away. Sadly it did not.
You can do the head gaskets. If you need any quick answers I've done it a few times. Lots of great advice here but every time I needed it in a pinch, it was the weekend and everyone was working on their own rovers instead of watching the forums. Just PM if you need a number.
Stick with the CHF 11-S. Not the 202.
Any chance you mistakenly inserted one of the "longer" threaded bolts (maybe, the A/C compressor bolts) into the wrong hole and cracked the head while torquing down the bolt?
Those I got from Autozone. They told me it for Landrover. Any recommendations or alternative fluid from autozone? Thanks
Thanks, At first I thought that the bolt went too far inside when the leak started. As I remember, there are no bolts connected to the other side of the gap. Though I love these trucks, I getting disappointed with all the problems Im having recently with both of my discos at the moment. they are leaking everywhere. This will be the 2nd time Im replacing the head gasket on this one.
Blakesrover
Feb 21, 2013 01:43 AM
JBEGIN
Jun 27, 2009 12:38 PM
