Cooling System Pressure Test
Old Jun 3, 2020 | 02:25 AM
user 739349's Avatar
Banned
Default Cooling System Pressure Test
I bought my disco two years ago and have always had intermittent problems with coolant leaks. I replaced the water pump and thermostat, which did seem to help. When the leaking is bad I notice "aerated coolant plumes" aka smoke starts to billow out from under the hood on the driver's side. Eeeks. I notice this when my coolant levels are low.
Today I pressure tested the cooling system for about an hour (did not go above 12 psi) and found two areas of concern. I'm looking for some advice on what could be happening and ideas on how I can further track down the origin of this leak. Also, the heater hoses are dry...
Here's the first area of concern and a smaller leak:
view from beneath front passenger side
Here's the second, much larger area of concern:
view from beneath back driver's side (the leak is dripping heavily onto the exhaust system)
view from beneath back driver's side (this is the area where the leak is originating)
Old Jun 3, 2020 | 07:20 AM
XRAD's Avatar
I'm pretty sure its the head gaskets......especially the last pic
Although I did have a leak from the heater hoses at the firewall which ran down the starter and right rear of block.....
Old Jun 3, 2020 | 07:26 AM
Sixpack577's Avatar
+1 on the head gaskets, and it could also be from where the lower intake manifold meets the block.
Old Jun 3, 2020 | 07:55 AM
ahab's Avatar
Good call on the manifold. Since it appears to be coming down both sides of the engine it's either both headgaskets (somewhat unlikely given that it's otherwise running and driving pretty well), or a common failure point like the manifold that could be finding its way to each side.
Old Jun 3, 2020 | 10:17 AM
cvhyatt's Avatar
Should we just add "replace head gaskets" as a preventative measure for all new owners? We already recommend replacing coil packs and presumably most people take the intake off to get to that, so why not add intakes to this (especially considering this is a common failure point).
Old Jun 3, 2020 | 10:39 AM
ahab's Avatar
Well, cvhyatt, to be clear, I meant common as in relative to both sides, aka, a common point in the middle. I wasn't implying that in addition to HGs, intake gaskets commonly fail. Hell, they may, I just don't have a good base of info there.
Old Jun 3, 2020 | 10:41 AM
RobisonService's Avatar
The leak in the photo could be an intake gasket, or an intake gasket and one or both heads. On a newer Discovery I strongly suggest you DO NOT change head gaskets. Live with the leak. I have written quite a bit about how the blocks are prone to crack between head bolt bores and water jackets and if that happens when you release and re torque the block to change the gasket you will go from repairing an annoying leak to rebuilding the motor with machine work for flanged liners and block welding.
I do suggest starting with the intake gasket, unless you have a fiber optic camera to stick down from on top to verify the leak source. We often to that to be sure
Old Jun 3, 2020 | 10:42 AM
cvhyatt's Avatar
Ahh I totally missed that and read more into it than I should have. My mistake.
Old Jun 3, 2020 | 07:38 PM
Extinct's Avatar
I am on #14, never had an intake gasket coolant leak only. Not saying it is not possible, just never had one. Probably done at least 7 hg jobs. If the truck is not meticulously maintained it is on my to-do list. I have two in the queue at the moment where the owners pre-emptively replaced most of the cooling system before allowing them to fail and overheat - fully documented. That is the only case where I consider not doing hg.
Old Jun 3, 2020 | 08:55 PM
We have done these engines for 30+ years, and have done hundreds. I can say with certainty that we fix many intake leaks where the heads don't leak or don't leak excessively. Then again, there are cars where they both leak. Five years ago we still did head gaskets. We have seen too many go bad, shortly after repair, and now that the engines are older, we think the risk in head gaskets alone is not worth it most times. If you are an individual and it's only your time and some gaskets you may want to take the chance. From my perspective managing a large service department I would not.
RoverFL
May 13, 2015 08:51 PM
Vai2kdna77
Apr 17, 2015 01:22 PM
Savannah Buzz
Nov 17, 2013 06:51 AM
Disco C
Jul 11, 2010 08:51 PM
mac25dm
Jan 21, 2008 08:21 AM
