Corroded wheel...any hope?
Old Feb 8, 2008 | 04:11 PM
DuplinDisco's Avatar
Default Corroded wheel...any hope?
One of my wheels is quite corroded. Tried using some Eagle One on it...it helped but not much. Is there anything, besides a sander[:-], that will remove the corrosion?
Old Feb 8, 2008 | 06:00 PM
XBlade's Avatar
Default RE: Corroded wheel...any hope?
Flitz metal polish
Old Feb 8, 2008 | 06:15 PM
spoon's Avatar
Angle grinder with a wire wheel on it?
Old Feb 8, 2008 | 06:28 PM
Sand dunes. Mine never shined so well as after a day in the sand.
Old Feb 8, 2008 | 11:38 PM
Mark G's Avatar
Wait, it's an aluminum wheel, isn't it? Also, they're coated in aluminum paint and clearcoat I believe. At least mine are. If so, you'll ruin the finish if you get on it with anything abrasive. It looks likeit's either brake dust, or something like steel wool or grinding particles that rusted. I'd get some different wheel cleanerfor brake dust removal,then rub it with asoft brush that will get into the corners, or your fingers.
Old Feb 9, 2008 | 10:36 AM
okdiscoguy's Avatar
X2. Unless you plan on re-painting your rims, don't use sand papre. THat corrosion did not come form the wheel.
I used Mothers MAg and Aluminum polish lightly on the inside of my rims with one of those small foam ***** on a drill. Got the caked on brake dust off like magic. Then I used wheel wax as a topper after rinsing out the foam ball.
Old Feb 9, 2008 | 10:39 AM
ORIGINAL: okdiscoguy
Thanks...I'll give that a try.
Old Feb 9, 2008 | 10:54 AM
okdiscoguy's Avatar
Those little ***** on a shft are amazing, and you can buy repalcement heads for them. I think they are like $20 at wal-mart. They have bigger one's, but the small one's work great....
Old Feb 9, 2008 | 05:47 PM
Went and bought one along with the Mother's polish. I was able to spend an hour on it and have gotten 70% of it off. Hope to get the other 30% off tommorrow.
hellohelloo4
Apr 7, 2014 07:19 AM
Twins Disco
Dec 15, 2013 01:24 PM
antichrist
Mar 4, 2011 10:04 PM
Danny Lee 97 Disco
Apr 3, 2010 08:40 PM
Elhoff
Nov 16, 2006 02:31 AM
