Coupla Engine Install questions
Old Mar 5, 2020 | 12:51 PM
ahab's Avatar
Default Coupla Engine Install questions
First, for reasons can't explain, I didn't take many pics of the old girls before I took them apart. The driveline from the 04 is now comfortably in the 03 and I don't remember where the negative cable attaches. There's a geographically compatible spot on the lower part of the belt tensioner/alternator bracket, circled in red. Is this where the neg cable lands?
I also have a small 5" braided ground strap, does anyone have a pic of where that attaches? I seem to remember the back of the engine to the firewall, maybe?
This next one is more out of curiosity. The engine harness from the 04 has a small square two-pin Coolant Temp Sensor connector shown in the top pic. The harness from the 03 has a round CTS with 4 pins and a round two-pin connector, bottom pic. Is there a logical explanation for this?
Old Mar 5, 2020 | 01:04 PM
Sixpack577's Avatar
The braided ground strap goes from the rear of the driver's side(U.S) cylinder head, to the firewall.
Old Mar 5, 2020 | 01:05 PM
Jason Feuerstein's Avatar
That's the place.
There's a threaded stud on the back of the firewall on the driver's side that it attaches to with a 10mm nut. Make sure you get this right; unless there's a supplemental ground in the battery compartment, the only other return path goes through your parking brake cable.
Probably just changes in available parts.
Old Mar 5, 2020 | 01:06 PM
Sixpack577's Avatar
That is also where my negative battery cable grounds at.
As for the 03 to 04 plug difference, I don't know.
Old Mar 5, 2020 | 01:19 PM
ahab's Avatar
Thanks for all the quick responses. The CTS connector is a weird one. Assuming the value of the two different sensors is the same then there's no real problem but it seems weird to me that round plug, which is commonly found on newer cars, would be superseded by the older style plug on the newer truck. The available stock in the parts bin is certainly one explanation.
Old Mar 5, 2020 | 07:39 PM
PalmettoDisco's Avatar
Just a guess on the plug shape, but I would surmise Ford was transitioning to their own supplier, after the stock of BMW spec connectors were used up.
DakotaTravler
Jun 28, 2024 08:05 PM
ahab
Jan 1, 2020 04:32 PM
DakotaTravler
Jun 5, 2019 02:57 PM
Colorado David
Jun 12, 2018 07:49 AM
KlamathMatt
Nov 8, 2013 05:51 PM
