Couple questions
Old Nov 19, 2017 | 07:26 PM
stb616's Avatar
Default Couple questions
So M+S lights came on the other day. Drove fine prior to coming on. Shut it off and restarted a few minutes later. Lights on and in limp mode. Took until the 3rd restart for them to NOT come back on. I've driven it a few times since with no issue, but I don't trust it. Can this be fluke? Any chance there isn't actually anything wrong with it?
Is there an issue that usually causes the issue? No idea where to start and there NO qualified rover mechanics in the area. Any help or direction would be appreciated.
Also.... my front, pas side window seems to have fallen off the track. Got it back up but know I need to address the problem. Any help on what I need to track down on that one would also be appreciated.
Thanks much!
Old Nov 19, 2017 | 08:25 PM
Alex_M's Avatar
Very likely to be a fluke. Can be caused if your battery was low or if there is a ground somewhere not getting a good connection. Pretty normal.
As for the window jumping the track, just pull the door card off and give her a look.
Old Nov 20, 2017 | 01:01 AM
toofaroffroad's Avatar
This happened to me last winter. Only happened once o a cold morning. Turned the truck off and started it up again and it went away. Hasn't happened since.
Old Nov 20, 2017 | 09:13 AM
stb616's Avatar
Thanks. I feel better at least knowing it there's a chance it's a fluke.
Old Nov 20, 2017 | 09:51 AM
JUKE179r's Avatar
Check if you have a trouble code (P0563 - System High Voltage).
Check your battery cables connections at the battery and also the condition of your battery cables at the terminals (frayed wires, loose connections inside the terminals)...
Old Nov 20, 2017 | 10:10 AM
Sixpack577's Avatar
Plastic wheels break on the window regulators.
Likely the problem.
Old Nov 21, 2017 | 06:18 AM
stb616's Avatar
Likely the problem.
Where does one get these little wheels?
Old Nov 21, 2017 | 07:18 PM
Sixpack577's Avatar
Normally, you have to buy the whole window track(easy install).
But, apparently someone here sells the wheels, as they make them in a 3-D printer.
I was reading the thread a couple weeks ago.
Sorry, I had already replaced the track, otherwise, I would have bought the wheels, so I don't know any more about them.
Old Nov 22, 2017 | 04:46 AM
The Deputy's Avatar
https://landroverforums.com/forum/di...rollers-72533/
Old Nov 22, 2017 | 10:13 AM
Motorhead1's Avatar
Failing XYZ Switch also causes those symptoms.
Durfee
May 7, 2006 11:02 PM
thairs
Apr 13, 2006 05:50 PM
AndrewBone
Aug 4, 2005 01:17 AM
UNCRover
May 10, 2005 02:45 PM
Bene
Freelander
May 10, 2005 01:41 AM
