A couple random leak questions
Old Dec 21, 2008 | 06:48 PM
04BluDisco's Avatar
Default A couple random leak questions
Wanted to see if anyone had any thoughts on a couple random leaks I've noticed recently.
1) recently tightened down the steering box (jacked it up, centered it, snugged the star bolt, tightened the lock nut, etc.). Noticed today that there is a slight leak out of where the bolt goes in. Checked it for tight. (it's tight). I've flushed the steering system, etc..... Any thoughts? Anythng I am missing? Are these just prone to leaking? It didn't leak before I screwed around with it...
2) seems I am getting a little seepage from behind the steering pump pulley.... minor, but annoying... any fixes for this, or is it the beginning of the swan song?
2004 Disco 2A, 63K on the clock.
J
Old Dec 21, 2008 | 07:12 PM
Default RE: A couple random leak questions
Power steering stop leak.
As you need to add power steering fluid add the kind that has stop leak in it.
Rover power steering pumps are leak prone, they come that way from the factory.
Old Dec 21, 2008 | 07:20 PM
04BluDisco's Avatar
Sounds like a solution to both issues... I'll give it a shot.... I haven't ever used this stuff, but I'll try it out.
Thank you!
J
Old Dec 21, 2008 | 07:36 PM
Try some Lucas p/s stop leak, works pretty well.
KinverTurtle
Dec 16, 2014 09:41 AM
MoShadeTree
Apr 19, 2013 09:45 AM
honda50r
Mar 5, 2012 02:23 PM
adam123
Apr 5, 2011 09:11 AM
tubadude
Jan 12, 2009 09:36 PM
