Crank Position Sensor
Old Jan 21, 2023 | 09:50 AM
Dave18102's Avatar
5th Gear
Default Crank Position Sensor
In the process of swapping out my malfunctioning CPS and tried the Autozone/Duralast route since it was in stock. Was hoping for a Bosch unit like others have received. Anyone have an idea if this is a Bosch or some knockoff brand that I’ll have to swap due to inferior quality.
Old Jan 21, 2023 | 11:55 AM
andino's Avatar
The bosch one I got from the duralast box was branded as bosch on the part itself.
Old Jan 22, 2023 | 11:05 PM
cunuckgaucho's Avatar
I just replaced my CPS and would like to share a tip that made my life much easier. Removing the air meter to throttle body unit( I kept the MAF and top of air filter box attached durring removal) allowed me much easier access to the unplugging the unit from the harness. Rather then come at it from above you come in at the plug almost horizontal.
Old Jan 22, 2023 | 11:22 PM
Best4x4's Avatar
That's not a Bosch they're clearly stamped Bosch, I ask to look at the part before I buy it to verify a Bosch vs aftermarket part.
Old Jan 23, 2023 | 06:22 AM
Dave18102's Avatar
5th Gear
Thanks for the info. 👍
Old Jan 25, 2023 | 10:25 PM
Brandon318's Avatar
My spare Bosch CPS' have silver shrink tubing on the wire too, FWIW.
CollieRover
Nov 30, 2017 01:34 PM
buick215
Apr 15, 2015 11:48 AM
vette427sbc
Sep 5, 2014 10:37 PM
94svt50
Apr 13, 2012 07:52 AM
0304Disco
Oct 27, 2011 01:12 PM
