cranks but won`t start
Old Oct 20, 2016 | 03:16 PM
wdelacru1's Avatar
Default cranks but won`t start
Hi everyone,
Which is the best way to remove a camshaft position sensor. I am having problem trying to located.
thanks
Old Oct 20, 2016 | 04:01 PM
CharlieV's Avatar
The camshaft sensor is on the front cover--you are talking about cam, not crank sensor?
To get to it you will need to take the fan shroud and fan off, and remove the belt. I am not with my rover today, but I think it is right below the water pump and behind the main pulley, and there is one bolt that you can get a wrench on at the top driver side of the main pulley. I don't know whether you can squirrel the sensor out from there with the main pulley in place--I've always done it the with the pulley off. The connector, which goes toward the passenger side, is in a keeper that you can work the main side of the connector out of.
Honestly, it is in a tedious spot. Maybe someone else can chime in. I've never messed with mine with the main pulley on.
dmatranga
Feb 5, 2013 12:27 AM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
J dog
Sep 8, 2008 07:46 AM
unco
Jan 28, 2007 02:56 AM
