Cranks, see RPMs, but not start
About a few months ago I noticed that the car took two cranks to start. Usually it happened during the day, so I presumed that something happened when the car was exposed to heat. Over time, the issue became a bit worse. The culmination happened yesterday when the car died while I was coming to a stop sign next to my parents' house. Crank Position Sensor? That's what I thought. Replaced the not-so-old Bosch unit with a new generic part from AutoZone. It cranks, but does not start. Other interesting info:
1. When I crank, UltraGuage shows 170 rpm
2. When my exhaust was off (had to do it to get to CPS), I could smell gas.
3. All fuses related to ignition are okay.
Something does not add up. Seeing RPM on crack means I CPK works and I get a spark. Smelling fuel means I got fuel (> 1/4 tank). Any ideas?
Thank you,
--mc
Thank you,
--mc
No codes related to ignition, fuel pump. Once in a while I get a code related to a cat (0430) and that's about it. My LTFT is high in both banks--need to reset fuel mappings.
If the fuel pressure is low, what am I dealing with? Clogged filter? Faulty fuel pump? I presume those are not DIY jobs...
Try this, turn the key to position two, then off, position two then off, and then try to crank it. If it fires right up you have a weak fuel pump or possibly an injector leaking which is causing the fuel rail to loose pressure.
If you have an SAI equipped D2 a new fuel pump off of Ebay is right at 50.00 for the entire unit. Takes maybe 30min to swap out.
krazzz
09-28-2009 09:38 AM
