Cranks, see RPMs, but not start
Old Jul 4, 2018 | 07:26 PM
mr. choodles's Avatar
Default Cranks, see RPMs, but not start
About a few months ago I noticed that the car took two cranks to start. Usually it happened during the day, so I presumed that something happened when the car was exposed to heat. Over time, the issue became a bit worse. The culmination happened yesterday when the car died while I was coming to a stop sign next to my parents' house. Crank Position Sensor? That's what I thought. Replaced the not-so-old Bosch unit with a new generic part from AutoZone. It cranks, but does not start. Other interesting info:
1. When I crank, UltraGuage shows 170 rpm
2. When my exhaust was off (had to do it to get to CPS), I could smell gas.
3. All fuses related to ignition are okay.
Something does not add up. Seeing RPM on crack means I CPK works and I get a spark. Smelling fuel means I got fuel (> 1/4 tank). Any ideas?
Thank you,
--mc
Old Jul 4, 2018 | 08:29 PM
Saturnine's Avatar
Codes?
abran's Avatar
Fuel pressure could be too low. Check pressure on fuel rail.
or, try to turn ignition to 2nd position 5 times before trying to actually crank engine. Theory is you will build up full rail pressure by cycling the ignition before starting.
Old Jul 4, 2018 | 10:11 PM
No codes related to ignition, fuel pump. Once in a while I get a code related to a cat (0430) and that's about it. My LTFT is high in both banks--need to reset fuel mappings.
If the fuel pressure is low, what am I dealing with? Clogged filter? Faulty fuel pump? I presume those are not DIY jobs...
Old Jul 4, 2018 | 10:27 PM
Saturnine's Avatar
Why wouldnt those be DIY?
There is no fuel filter on the D2 or so i have been told -- fuel pump is under the carpet in the rear, couple of bolts and you've got it out. There is a schrader valve off of the fuel hard line -- get a tester and see what the pressure is and go from there.
Old Jul 5, 2018 | 11:48 AM
Best4x4's Avatar
Try this, turn the key to position two, then off, position two then off, and then try to crank it. If it fires right up you have a weak fuel pump or possibly an injector leaking which is causing the fuel rail to loose pressure.
If you have an SAI equipped D2 a new fuel pump off of Ebay is right at 50.00 for the entire unit. Takes maybe 30min to swap out.
Old Jul 5, 2018 | 08:52 PM
It was the fuel pump. The pressure was too low, about 4PSI. Turning the key into the II position multiple times did nothing. What we learned today:
1. Keep the UltraGauge plugged in to check the RPMs.
2. Get a fuel pressure gauge.
Old Jul 6, 2018 | 07:37 AM
No Doubt's Avatar
nice follow up. Glad that you got it sorted
Freedom38
Jul 12, 2016 10:40 PM
Jabez
Apr 7, 2016 06:30 AM
shady milkman
Oct 3, 2012 01:31 PM
krazzz
Sep 28, 2009 09:38 AM
crownaviation
Jan 12, 2008 09:52 PM
