Crankshaft Position Sensor (CPS) Heat Shield DIY
Old Jun 10, 2025 | 07:07 PM
Brandon318's Avatar
Default Crankshaft Position Sensor (CPS) Heat Shield DIY
Recently replaced my CPS and decided to take a little extra time to up the heat deflection properties of the fiberglass heat shield.
I ended up cleaning it really well, brushed on a layer of epoxy, and basically leafed aluminum foil on it. I let it cure overnight and then did a second layer. Drill out the two bolt holes and voila.
Old Jun 11, 2025 | 06:13 AM
rikkd's Avatar
Looks great!
Old Jun 11, 2025 | 11:49 AM
JohnZo's Avatar
Heat transfer-wise, a bit of an air gap would provide additional insulating value. So, loosely wrapping and crinkled vs glue on would provide better heat shielding. This looks better though and is a definite improvement, reflecting radiant heat.
I cut some sheet aluminum (old license plate) and mounted it between the sensor and exhaust pipe, similar to the way some of the engine and transmission mounts are shielded. The tranny had an unused bolt hole nearby. It's good to over-protect this sensor vs under-protect.
Old Jun 11, 2025 | 07:24 PM
Extinct's Avatar
This is the way.
Old Jun 11, 2025 | 09:59 PM
Brandon318's Avatar
To be fair, there's already an air gap between the sensor and the heat shield, but definitely don't see how adding another would hurt! haha
Old Jun 11, 2025 | 10:24 PM
disco96sd's Avatar
I installed a tiny fan near mine - LOL
Old Jun 11, 2025 | 10:28 PM
Brandon318's Avatar
Ducted the AC vent from inside to blow on it? Smart move.
Mark1107
Sep 8, 2022 09:15 PM
greghartnz68
Jan 19, 2022 11:47 PM
Brandon318
Aug 2, 2021 07:10 AM
Brandon318
Jul 28, 2021 10:47 AM
loanrangie
May 17, 2016 04:36 AM
