Crankshaft Position Switch issue
Old May 21, 2012 | 08:24 PM
shikomizue's Avatar
Default Crankshaft Position Switch issue
I have a 2000 Discovery 2 se. I noticed it would start when it was cold. Just noticed that after it was warm it would just crank and not start. Other forums suggeted to replace the sensor. I got the heat shield off with a 7mm socket no problem. I am have a hard time getting the sensor out. What size socket is it? Any other suggestions? Thanks
Old May 21, 2012 | 09:05 PM
Look though the stickies on the DII page, there is a write up on how to replace it.
Old May 21, 2012 | 11:17 PM
Let new one be plugged in and hang before you bolt it back in. Every spacer goes back same way it came off or it won't work. See attached.
File Type: pdf
Old May 24, 2012 | 01:37 PM
shikomizue's Avatar
I replaced the sensor and it fixed the problem 100%. Thanks for the help. I purchased the part from autozone for $60 and LR Dealer had it for $136 The same Bosch part. Thats quite a mark up.
Old May 25, 2012 | 10:50 AM
And just think shikomizue, AutoZone has a mark up on it too.
That part probabaly cost AutoZone $30.
Old Jul 19, 2012 | 07:04 PM
grose's Avatar
I have the same problem with cps. I have the shield off and the 2-8mm nuts off, but the sensor body won't come out, at least not easily. Should it not just pull out? Any help? I don't want to damage any parts.
EVN137
Oct 6, 2024 12:48 PM
ViennaDisco
Sep 25, 2010 04:16 PM
hendoc3
Jun 25, 2010 11:56 AM
vserduchka
Dec 4, 2009 05:57 PM
smi8387
Feb 7, 2006 01:15 PM
