Crazy coolant leak I cant find
Old Jun 5, 2022 | 09:49 AM
grcurry's Avatar
Default Crazy coolant leak I cant find
I have the weirdest coolant leak issue. It only leaks 2 twice a week and after running and driving then shutting off. It look like its coming behind a freeze plug or water pump but its ruining and dripping down the side of oil pan. When I pressurize the system and try and make it leak, The system will not leak. This is the craziest thing I have ever seen. Has anyone had this issues? If so could you tell me whats going on so I can fix this crazy problem.
Thanks
Old Jun 5, 2022 | 10:18 AM
RA122125's Avatar
Banned
Front of the engine, or rear?
Old Jun 5, 2022 | 01:40 PM
Richard Gallant's Avatar
Get some cooling system dye and a UV light - sometimes it is the only way to find the source of weird leaks
Old Jun 5, 2022 | 09:33 PM
redwhitekat's Avatar
Either water pump weeping hole or timing chain cover / oil pump. Very common places where a leak develops and hard to find. Watch the Atlantic British video on oil pumps. He points out the weak spot
Old Jun 6, 2022 | 10:11 AM
redrover75's Avatar
If it is the weep hole, time to replace it...
Old Jun 7, 2022 | 06:07 PM
grcurry's Avatar
It will not just leak it dumps out a lot at one time. Then it will not leak any more in a few days. all most like reliving pressure.
Old Jun 8, 2022 | 06:17 AM
that would be coming out of your coolant tank cap pressure relieve change cap and thermostat
Old Jun 9, 2022 | 08:36 AM
grcurry's Avatar
Default Coolant tank cap is not leaking
Coolant tank cap is not leaking the leak is coming from underneath somewhere it’s either behind the freeze plug or somewhere around that water pump
xxjtvxx
Dec 19, 2011 07:35 PM
Disco C
Jul 11, 2010 08:51 PM
RoverRookie
Sep 9, 2009 07:00 PM
ccvalentino
Jan 6, 2008 08:11 AM
