Crazy coolant leak I cant find
I have the weirdest coolant leak issue. It only leaks 2 twice a week and after running and driving then shutting off. It look like its coming behind a freeze plug or water pump but its ruining and dripping down the side of oil pan. When I pressurize the system and try and make it leak, The system will not leak. This is the craziest thing I have ever seen. Has anyone had this issues? If so could you tell me whats going on so I can fix this crazy problem.
Thanks
Thanks
Either water pump weeping hole or timing chain cover / oil pump. Very common places where a leak develops and hard to find. Watch the Atlantic British video on oil pumps. He points out the weak spot
that would be coming out of your coolant tank cap pressure relieve change cap and thermostat
