Cross thread my spark plug well #7
Old Mar 4, 2020 | 12:31 PM
  #21
Sixpack577's Avatar
I would check compression before swapping a coil, just because it's quick and easy.
Since the plug is new, you will be a able to get a good "read" of it, as in normal or rich.
Old Mar 6, 2020 | 06:12 PM
  #22
Carlos Man's Avatar
Thoughts.... could this be the culprit?
Old Mar 8, 2020 | 06:55 PM
  #23
Carlos Man's Avatar
New plug in and cleaned the throttle body... disco runs worse got a cyl 4 misfire code in about 5miles of driving.
I’m stumped...
any of you all know an easy way to reach the coil pack so I can change the #4 wire?
Old Mar 9, 2020 | 07:08 AM
  #24
WaltNYC's Avatar
That hose from driver's valve cover to air intake looks terrible. The fitting on the valve cover as well.
Old Mar 9, 2020 | 07:27 AM
  #25
Carlos Man's Avatar
it’s been cleaned
Old Mar 20, 2020 | 08:02 PM
  #26
Carlos Man's Avatar
Default Problem solved
Removed the IM and installed new coil packs, ignition wires, IM gasket, air filter, and did the PCV mod.
runs great with no codes after 10miles
lrjon
Feb 15, 2020 04:14 PM
Betty4banger
Nov 30, 2018 01:01 PM
cmb6s
Feb 17, 2015 08:30 PM
Danny Lee 97 Disco
Jun 22, 2010 09:01 PM
adwarren78
Mar 24, 2009 07:52 PM
