Cruise Control vacuum test?
Solder a 50 watt/6 Ohm resistor in parallel to one of the LED brake lights and mount the resistor to metal so it can dissipate the heat from the resistor.
https://landroverforums.com/forum/bu...e2/#post696461
I did this also for my turn signal LEDs. I had a hyperflash/strobe light effect from the flasher unit. I fixed this by soldering in parallel one 50 watt/6 Ohm resistor to each front left and right side LED turn signals.
