Cruise control working itermittently
Old Jan 7, 2008 | 10:21 AM
Chrisinhouston's Avatar
Default Cruise control working itermittently
One time it works and then the next it doesn't. The light comes on either way on the switch on the dashboard, it just doesn't alway set the speed. Then later on it works fine. Go figure, a LR with an attitude problem?
Any ideas?
Old Jan 7, 2008 | 11:05 AM
jmt's Avatar
jmt
Default RE: Cruise control working itermittently
Check the switchies on the steering wheel.
I would asusme this could carry over to the Disco, but on my old Explorer, they had packed the switch with so much grease that it wouldn't allow it to work at time. I popped off the peice and cleaned the connectors out with an alcohol soaked q-tip.
Just a thought.
Old Jan 7, 2008 | 12:09 PM
suntattoo80's Avatar
what yr is she?
mine had a vaccume hose cracked on the cruse unit and it would work sometimes. others it would not work. the unit is located on the pass side inner fendre well...
Old Jan 7, 2008 | 03:57 PM
okdiscoguy's Avatar
might also check the switch on the brake pedal. It has a plunger on it and it gets pressed in sometimes. Make sure it it fully extended...
Carlton1
Jul 25, 2012 07:51 AM
csn4646
Aug 28, 2009 09:16 PM
2K Disco II
Aug 11, 2008 10:42 AM
cosmiccharlie79
Jun 16, 2008 09:13 AM
bklahl
Aug 29, 2007 11:20 AM
