Cylinder Heads, going the way of the DoDo bird?
Old Feb 22, 2023 | 10:36 AM
dswilly's Avatar
Default Cylinder Heads, going the way of the DoDo bird?
Just thinking about cylinder heads during my coffee time this morning and started to wonder if availability is or will be a concern as we keep these old trucks going at 20+. I know you can only deck them a few times and would guess most have had at least one pass if they had a head gasket job done. Which is, as we know, a common procedure. I read somewhere SAI heads are scarce, I think. Will this be the death-nail for D2 Buick motors? Or will we all be having our heads TIG welded over the entire deck and machined back down to keep them going. Let me know your thoughts on this.
Old Feb 22, 2023 | 01:17 PM
Richard Gallant's Avatar
Well that depends - I did my head gaskets 3 years ago and I figure they are good for at least another 7 or so and I have a spare set so that should be 17 years. But yes eventually there will be no parts, but if the climate change force to electric continues fuel will be a far larger issue unless you are diesel and even then it is dodgy.
Old Feb 22, 2023 | 02:01 PM
Discorama's Avatar
There is always the option to swap it for a different motor (if you jurisdiction allows that easily). The truck can get only better from that ... reliability, fuel economy, power.
Old Feb 22, 2023 | 09:35 PM
Alex_M's Avatar
This is the reason “head saver” shims exist. I haven't specifically looked, but I'm sure someone makes them for old Buicks. If not, they would be easy to have manufactured.
Alternatively, the Pistons can also be milled to bring the compression ratio back into spec if you ever get to the point heads are hard enough to find.
All that said, I think the factory spec for maximum head deck removal is pretty extreme. I would have no concern having a bit more material removed than is technically "allowable".
One day, yes, but that problem is a long... Long way off.
Old Feb 23, 2023 | 09:18 AM
dswilly's Avatar
Shims! I never knew there was such a thing! How do they work, just insert above or below a new head gasket or do you use two head gaskets to sandwich the shim. Looks like rover is an option here - https://innomach.com/images/IMS-CATALOG.pdf
Old Feb 23, 2023 | 10:45 AM
XRAD's Avatar
also, cometic makes head gaskets for our v8's. Maybe they also have different thicknesses.....
Old Mar 1, 2023 | 11:27 PM
Discorama's Avatar
I am going down the rabbit hole of an engine rebuild right now. Just read about the advantages of Cometic head gaskets in another thread. They make head gaskets of different thicknesses from 0.027 to 0.120 compressed. As often as regular gaskets fail, maybe that is a more sustainable solution?
WaltNYC
Jan 27, 2022 05:24 PM
TheWhiteRover
Dec 8, 2016 10:18 AM
WARWAGON
Sep 3, 2012 03:20 PM
lipadj46
Jun 27, 2009 12:05 PM
djones70
Apr 15, 2008 07:21 PM
