D&D & their Crower cam
Old Mar 20, 2014 | 08:19 PM
  #21
Dane!'s Avatar
Zing!
Old Mar 21, 2014 | 06:46 AM
  #22
04duxlr's Avatar
$200 total kinda sucks. If I needed it now I think I'd just go with a stock 4.6 cam, but I'm cheap. If nothing else, you know you are getting a well made camshaft from a reputable supplier rather than some rebaged junk sourced from India or China.
Old Mar 21, 2014 | 06:51 AM
  #23
drowssap's Avatar
or send an email off to GPR was they put HP cams in all their rebuilds, they probably have a box of them.
Old Mar 21, 2014 | 09:21 PM
  #24
ImQuattro's Avatar
I did email them with no response.
Old Mar 22, 2014 | 12:38 AM
  #25
robertf's Avatar
You may want to consider sending a used cam to Delta Camshaft and having them weld/regrind it to your specs. I've used them in the past and they are high quality and quick turn around. They include a t-shirt with purchase too Delta Camshaft
I haven't used them for a rover cam yet.
Old Jan 19, 2024 | 02:54 PM
  #26
MichaelW's Avatar
Originally Posted by grandkodiak
... otherwise you are basically putting a bigger mouth on the same size straw. all an engine is is an airpump, bigger cam, more air, more flow...in AND out, or gains will be minimal. if you just swap a cam, you are throwing your money away.
...If its done literally just by swapping the cam its going to run like crap, the computer is going to relearn how to run back at its baseline and all will be for naught.
Resurrecting this thread, as I'm dealing with high NOx levels and trying to narrow down whether my cam is to blame (thread on my emissions woes here...). I have a '99 D1 (4.0 V8) that the previous owner swapped a 4.6 V8 into, along with a level 2 crower cam (53229). As far as I know, the engine is bone stock otherwise. I've never installed an aftermarket cam, so my knowledge on them is pretty limited - are you essentially saying that by dropping in a performance cam without doing making any of the other adjustments discussed in this thread, you're effectively just pulling more air into the engine? Or is that an oversimplification? My fuel trims pretty much look healthy so I haven't definitively determined that my engine is running lean, but that'd be the usual reason for high NOx. O2 sensors, cats, and fuel injectors are all brand new / seem to be doing their job.
Also re: your second quote, are you just referring to long term trims recalibrating themselves over time to compensate for the increased airflow - and in turn, the engine running like a stock one anyway?
To anyone else viewing this... on the off-chance you have a 4.6 with a level 2 crower cam in it and you've been able to pass emissions, please drop me a DM if you wouldn't mind me picking your brain. I've scoured the forums and haven't found anyone who's made this swap in a state that requires emissions tests...
ImQuattro
Feb 10, 2015 02:30 PM
Rover Newbie
Jun 7, 2014 09:11 AM
ImQuattro
Mar 26, 2014 11:58 AM
BCDisco2Lando
Aug 7, 2013 10:19 AM
